Axminster Workshop Drill Press Table
109540
From £59.98 £49.98
In Stock
  • Upgrade to a woodworking friendly drill press table
  • Universal design fits a wide range of drill presses
  • Large work surface for greater support
  • Adjustable fence and sliding stop block for repeat drilling
  • Suitable for drill press tables up to 450mm wide and 50mm thick
The Axminster Workshop Drill Press Table turns your Drill Press into a far more woodworking friendly machine. Its universal design and simplicity of fixing allows it to fit onto a wide range of drill presses. T-slots on the underside allow the three holding clamps to be positioned easily and adjusted to a wide variety of shapes and sizes of drill press table.
The standard drill table is designed around metal working. This super upgrade gives you a far larger work surface for greater support of larger work pieces and allows you to drill accurate repeat holes. The table measures in at 605mm x 300mm x 25mm thick offering spacious solid support. The unique design provides clearance for the height adjustment crank handle on most drill presses. A 50mm high adjustable fence and sliding stop block offer greater work support and increased accuracy. The table comes with five clamps in total, three for use on the underside and two for use as work holding clamps on the top. The removable insert allows you to drill completely through the workpiece without damaging the table. Suitable for drill press tables up to 450mm wide and 50mm thick.
Table Dimensions: 605mm x 300mm
Fence Dimensions: 600mm x 50mm
Drill Press Table Thickness: 25mm
T-Track Centre to Centre: 108mm
4.50 20
