Blum Modul 170 deg.Hinge & Cruciform Mount Plate With Screws
717588
717588
- All metal nickel plated hinge, 170° opening
- Spring-closing mechanism, slide-on top arm
- Nickel plated steel cruciform for Modul hinges, supplied with pre-mounted screws
- 3-dimensional adjustment (with mounting plate)
- Height adjustment ± 3mm
An all metal nickel plated hinge, with 170° opening. It has a spring-closing mechanism and a slide-on top arm plus 3-dimensional adjustment (with relevant mounting plate). Supplied with a nickel plated steel cruciform for Modul hinge with pre-mounted screws. Height adjustment is ±3mm.
Due to the nature of wide opening hinges as the 170° Modul, unavoidably a gap the diameter of a pencil can be inserted into the hinge. Therefore for child safety, we would advise where cabinets are accessible to children, safety latches should be fitted to avoid possible accidents.
