Bosch FSN Guide Rails
AX867309
AX867309
- Bosch FSN guide rails
- Fitted with splinter guard and anti-slip pads
- For GKT 55 GCE plunge saw
- Fits to Bosch routers with adaptor
Axminster Workshop Sawhorses (Pair)Special Price £79.98 £66.65 was £99.98 £83.32 Save £20.00 £16.67
Show more
Show less
Bosch guide rails available in 2 lengths: 800mm or 1,600mm. Fittings directly to Bosch GKT 55 GCE plunge saw and to Bosch routers with a router adaptor. Fitted with a splinter guard that is cut perfectly with the saw blade on the first cut, the anti-slip strip on the underside of the rail can eliminate the need to clamp on some materials. Clamps and other rail accessories also available.
Please note: plastic end caps are no longer supplied with the rails.
Model | FSN |
