Bosch 5 Piece Brad Point Drill Bit Set (Hex Shank)
610791
From £11.98 £9.98
  5. Half Star
11 Reviews
Low Stock - Ready to dispatch
  • Drill bits with 1/4" hex shanks, great for cordless drills
  • HSS precision brad point for wood, sizes: 2, 3, 4, 5 and 6mm
  • Clean cutting with good chip clearance
  • Supplied in a plastic case
These HSS brad point drill bits will cut a very clean hole in wood, with a centre point and cutting spurs they are very precise. Fitted with a 1/4" hex shank they are suitable for use with quick change bit holders making them great for use in cordless tools. Ground from solid metal they are very strong. Supplied as a set of 5 in a plastic case containing the following sizes: 2, 3, 4, 5 and 6mm.
4.30 11
