Bosch BiM Plunge Cut Blades (Starlock)
701444
701444
- Suitable for non-ferrous metal such as copper pipe and aluminium
- Cuts in plaster board and other similar materials
- Bi-metal plunge cutting blade (BiM)
- 20mm depth of cut
- Blades will cut flush to a surface
Bosch BiM C-Tec Precision Plunge Cut Blade (Starlock) - 65mmFrom £16.78 £13.98
Bosch BiM C-Tec Precision Plunge Cut Blade (Starlock) - 32mmFrom £13.38 £11.15
Show more
Show less
A range of bi-metal (BiM) plunge cutting blades that are suitable for non ferrous metal cutting such as pipework and aluminium as well as cuts in dry walling and other similar materials, the blades will cut flush to a surface and allow you to plunge into say dry walling to fit socket boxes etc.
Starlock blades are suitable for Bosch, Makita and Fein (10mm) and other Multi-Tools using the Oscillating Interface System (OISâ„¢). The Starlock fitting ensures a secure fit with maximum power transfer.
Blade Width | 10 mm |
EAN Barcode | 3165140492447 |
