Bosch GCM 12 GDL 305mm Axial-Glide Mitre Saw
501681
501681
From £1,152.98 £960.82
  5. Half Star
63 Reviews
Low Stock - Ready to dispatch
  • Axial-Glide system allows positioning against a wall
  • 104mm maximum cut height, 341mm width at 90°
  • Axial-Glide system gives the smoothest possible saw action
  • 52° left and 60° right mitre cutting
  • Maintenance-free with sealed bearing
  • Integrated sliding work supports, left and right
  • All controls to the front of the machine
  • Dual laser-line, precision 'Freud' saw blade
  • Groove cutting function
  • 3 year warranty available (registration required)
This unique saw features Bosch’s 'Axial-Glide'™system, which provides the smoothest and most precise cutting action of any mitre saw on the market today. Rather than using guide bars, the GCM 12 GDL features vertical and horizontal hinged arms with sealed bearings. The arrangement guarantees a maintenance-free, super smooth and highly accurate action.
In addition, the design saves space. You do not need to allow for guide bars projecting to the rear and as the controls for setting mitre and bevel cuts are at the front of the machine; you can position the GCM 12 GDL against a wall. The saw has a large cutting capacity and wide ranges of both mitre and bevel angles. A laser projects a dual line defining each side of the kerf for precise line-up before cutting. A depth of cut limiter allows you to groove or rebate.
The table has pull out material supports right and left, with stops for repeat cuts. The back fence, with a total length of 1,016mm offers maximum work support. The Axial-Glide™ system locks for transport.
Warranty Bosch Professional 3 Year Warranty (Registration Required)
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
Registration required within four weeks of purchase. More information can be found on the Bosch warranty website and in the warranty conditions.
4.60 63
