Axcaliber Contract TCT Saw Blade Neg Rake - 305mm x 3.2mm x 30mm 72T
200375
200375
From £47.78 £39.82
7 Reviews
  • Buy 3 for £45.40 £37.83 each
  • Buy 6 for £43.01 £35.84 each
  • Buy 10 for £38.23 £31.86 each
In Stock - Ready to dispatch
  • Generously sized TCT tips brazed onto tensioned quality steel plates
  • Negative rake (72 teeth), gives a smooth, safe cut
  • Perfect choice for mitre saws
  • 3.2mm kerf
  • 30mm bore
Get the best blade for your task
The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price.
Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from hand held power tools right up to large panel saws used in production workshops, you will be certain to find
a blade to suit every requirement. Bore size 30mm. A range of bore reducing bushes are available. These negative rake blades are a perfect choice for a mitre saw, the rake of the tooth will help prevent the blade from grabbing, creating a smoother, safer cut. The finish is 1st class on all natural timbers or man made boards.
4.10 7
