Deluxe Stainless Steel Pizza Cutter Kit
- Easy to make project; simply turn between centres
- Durable, Stainless Steel cutter
- Removable for easy cleaning
Micro-Mesh Soft Touch Abrasive Pads 50 x 50mm - Mixed (Pkt 9)From £15.58 £12.98
Cut your pizza with style and ease with this useful kitchen utensil. Featuring a durable, Stainless Steel cutter and heavy-duty chrome components, this pizza cutter will not only perform, but will impress too. The 24kt gold plated washers add an elegant touch to your turned handle. A threaded insert allows you to conveniently remove the cutter from the handle making it easy to wash and keep clean. With a 4" Stainless Steel blade and a chrome finish, it's easy to make; simply turn between centres to the length of your choice.
Drill Bit Required | 1/2" |
EAN Barcode | 732068642457 |
