Easy Wood Tools Mid-Size EASY HOLLOWER™ #2
- Hollower #2 for mid‑stage interior shaping
- Ideal for hollow forms and medium to large bowls
- 12.7mm square section shaft provides excellent stability
- Solid carbide cutter keeps an edge many times longer than HSS
- No sharpening required - rotate the cutter to a fresh edge
- 355mm American Maple handle, copper ferrule for strength
- Easy Wood Tools are 100% made in the USA
The Easy Wood Tools Mid‑Size Easy Hollower™ #2 is a carbide woodturning tool designed for the mid‑stage shaping of hollow forms and the interior of medium to large bowls.
As the second tool in the Hollowing 1‑2‑3 system, Hollower #2 reaches deeper into the form and begins refining the interior shape after the bulk waste has been removed by Hollower #1.
Featuring a solid carbide cutter and a 12.7mm square section shaft, the Mid‑Size Easy Hollower™ #2 sits flat and steady on the tool rest, offering excellent stability and easy control with no sharpening required.
The longer 355mm American Maple handle provides secure leverage for deeper cuts, while the tool’s geometry allows smooth shaping inside areas that are no longer directly visible.
Hollower #2 is engineered for controlled interior shaping, improving transitions, smoothing surfaces, and following the developing contour of the form.
When held parallel to the floor at centre height, the square shaft keeps the tool stable on the rest, helping to minimise catches and snatches as you hollow deeper inside the vessel.
It provides a balanced combination of reach, control, and refinement before moving on to Hollower #3 for final finishing.
With no sharpening required, simply loosen the fixing screw and rotate the cutter to expose a fresh edge when dull.
Easy Wood Tools’ long‑lasting carbide cutters stay sharp many times longer than HSS and perform reliably on dry or green wood and acrylics.
What you get
Solid carbide cutter fitted as standard
355mm American Maple handle with copper ferrule for strength
12.7mm square section shaft for excellent stability
Colour‑coded handle for quick identification within the hollowing system
Engraved carbide cutter reference number on the shaft
Specifications
Overall length: 572mm
Handle length: 355mm
Shaft profile: 12.7mm square
Optional upgrade
Negative rake carbide cutters are available separately and work particularly well on acrylics, polyester, and resin, producing a smoother, finer finish as hollowing progresses.
