Festool CT15 E Cleantec Dust Extractor 230V
- High performance with variable suction power
- Ideal for general cleanup
- Large 15-litre capacity, suitable for wet or dry use
- Light in weight for easy portability
- Castors for excellent manoeuvrability
- Convenient flat top for power tools
- On-board storage for crevice and upholstery nozzles
The Festool CT15 E dry/wet extractor delivers high suction performance in a compact format. The machine, makes short work of clean ups around the jobsite: floors and worksurfaces. It has a large 15-litre capacity and is suitable for wet or dry use. (note a wet filter is required for wet extraction).
The Festool CT15 E extractor has a touch control panel, easily operated, even when wearing gloves. The suction is variable allowing you to match the suction power to the job in hand. The CT15 E is supplied with crevice and upholstery nozzles. Both nozzles store conveniently underneath the top of the unit. The flat top of the CT15 E is handy when it comes to putting your power tool down.
This is a highly mobile machine with two large wheels with a lockable brake and two smaller castoring wheels. The filter is easily accessible from the outside, there is no need to dismantle the machine to clean or change the filter. Re-attaching the hose to the exhaust outlet on the side of the machine turns it into a useful blower.
Supplied with: High-performance main filter, 3.5m suction hose diameter 27/32, SELFCLEAN filter bag, crevice nozzle and upholstery nozzle.
Please note, the CT 15 is a general use vacuum and not suitable for the extraction of hazardous waste.
A full floor clean kit is available as an optional extra.
