Festool DOMINO DF 500 Q-Plus Jointer & Assortment 1060 - PACKAGE DEAL
- Unique jointing system using DOMINO® shaped wooden dowels
- Patented routing principle with a wide range of adjustment options
- Stop positions for hole centres 16, 20, 22, 25, 28 and 40mm
Customers Also Bought
This package includes the DOMINO DF500Q-Plus and the 1060 Assortment.
DOMINO DF500Q-Plus
The 'DOMINO' is a unique jointing system using rounded loose tenons to join timber giving very strong accurate and precise joints. Combining exceptional versatility with simple handling for maximum precision, the DOMINO has a patented routing principle with a wide range of adjustment options to make it extremely easy to use. The machine's fence can be adjusted to cut slots centrally in 5 pre-set timber thicknesses and manually adjusted for other thicknesses. The dowels can be placed centrally, offset, in pairs or groups. There are retractable stops for accurate positioning from the edge of the workpiece. The jointer fence can be adjusted to 5 pre-set angles and is also infinitely variable between 0 and 90°. There are 6 different sizes of DOMINO available.
Supplied as a DOMINO Q-Plus version with the D5 cutter (for the 5 x 30mm), support bracket and Systainer T-LOC SYS3 187M case.
DOMINO Assortment 1060 in T-LOC SYS3 187M case
An assortment of DOMINO beech wood dowels plus 4, 5, 6, 8 and 10mm cutters for the DF 500 DOMINO machine. Includes 1,060 DOMINO dowels in the following sizes altogether in a Systainer T-LOC SYS3 187M case: 4mm x 20mm, 5mm x 30mm, 6mm x 40mm, 8mm x 40mm, 8mm x 50mm and 10mm x 50mm.
- Depth stops at 12, 15, 20, 25 and 28mm
- DOMINO Assortment with 1,060 dowels
- 4, 5, 6, 8 and 10mm cutters
