Festool TS 55-FEBQ Plus Plunge Saw , 2 x Guide Rails & Accessories
- Saw and Guide Rails an unbeatable combination
- 2x 1,400mm rails for cuts up to 2.8m long
- Accurate, powerful plunge cutting saw with thin kerf blade
An unbeatable sawing system
With an innovative new cutting blade and the same reliability Festool customers have come to trust, the TS 55-FEQ/FEBQ coupled with Festool guide rails is an unbeatable sawing system.
Improved performance
Thanks to the new, thin 1.8mm kerf blade, less material is removed, allowing the saw to work faster. This coupled with increased speed and exceptional torque, the TS 55-FEQ/FEBQ Plus can run up to twice as fast as previous models.
Safe
The control electronics Festool have included with the TS 55-FEQ/FEBQ Plus ensure speed and temperature control, as well as a spring loaded guide wedge positioned in front of the blade to prevent jamming.
Angles
A full range of positions are available, including undercuts, from -1 to 47 degrees. You can be sure you are making accurate cuts every time, even on an angle.
Healthy
Efficient extraction when attached to Festool's adapted system using an extractor with Bluetooth remote control automatic switch, or with a dust bag.
Easy to use
Festool's FastFix system has been incorporated into the TS 55-FEQ/FEBQ Plus, ensuring blade changes can be completed in a few easy steps. Once the blade is changed, the sawing speed adapts to the material.
Extra features
The slimline housing allows cuts to be made up to just 12mm from the wall, making this tool even more versatile. The TS 55 FEQ Plus is also supplied in the new Festool T-LOC handy case.
Festool TCT Saw Blade Thin Kerf Laminate - 160mm x 1.8mm x 20mm 52TFrom £87.98 £73.32
The combination of a Festool circular saw and the Festool Guide Rail makes a superb system for cutting sheet materials. The Festool TS 55-FEBQ takes a 1.8mm kerf blade; with such a narrow kerf it can cut at up to twice the speed of previous models. This fast and efficient plunge saw used with Festool's guide rails is unbeatable for ease and accuracy. The narrow kerf means it removes much less material. The angle adjustment from -1° to 47° allows a slight undercut for perfect butt joints. The cut line remains the same no matter what the cutting angle.
With two 1,400mm guide rails and rail connectors, ripping down the length of an 8x4 sheet presents no problems. The guide rails have a splinter guard for a clean finish. On the underside a cushion strip adds grip, two clamps come with the kit offering extra security.
Supplied with 2 x 1,400mm guide rails with anti-splinter guard, 2 x rail connectors, 2 x screw clamps and rail bag. The saw has a 42T thin kerf blade and anti-splinter device and is supplied in a Systainer SYS3 M 337 carry case.
N.B 230V version is known as model TS 55-FEBQ.
Benefits
- Includes 36 month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft
- Original parts guaranteed
- 14 day money back
EAN Barcode | 5052511125999 |
Bevel Angle Range | -1° to +47° |
Blade Diameter | 160 mm |
Bore Size | 20 mm |
Cable Length | 4 m |
Corded or Cordless | Corded |
Dust Extraction | 27 mm / 36 mm Outlet |
Kerf | 1.8 mm |
Max Depth of Cut @ 45º | 43 mm |
Max Depth of Cut @ 90º | 55 mm |
Motor Power | 1,200 W |
Nett Weight | 4.5 kg |
Plug Fitted | UK 3 pin plug |
Rating | Trade/Professional |
Saw Blade Speed | 2,000 - 5,800 rpm |
Sound Power Level LwA [Uncertainty K] | 101 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 90 dB(A) [3.0 dB] |
Spindle Lock | Standard Feature |
Voltage | 230 V |
