Makita 4350FCT Jigsaw
- Exceptionally low vibration
- 135mm maximum depth of cut
- Worklight illuminates cutting line
- Tool free blade change, integral blower
- Variable speed setting at rear of tool
- Soft start electronic speed control
- 3 stage pendulum cutting action
- Carry case included
The very low vibration of this model ensures that nearly all power is used in the cutting process and not wasted. Powerful with soft start and constant speed control along with quick and simple blade change that requires no tools. A work light illuminates the cutting line.
Supplied in carrying case complete with dust nozzle, baseplate cover, anti-splinter device and jigsaw blade set.
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
- Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
- The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
Blower | Standard Feature |
Corded or Cordless | Corded |
EAN Barcode | 088381080576 |
Max Depth of Cut Steel | 10 mm |
Max Depth of Cut Wood | 135 mm |
Model | 4350FCT |
Motor Power | 720 W |
Nett Weight | 2.4 kg |
Pendulum Action | Standard Feature |
Plug Fitted | UK 3 pin plug |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 95 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 84 dB(A) [3.0 dB] |
Stroke Length | 26 mm |
Stroke Rate | 800 - 2,800 /min |
Tilting Base | Standard Feature |
Vibration Cutting Sheet Metal [Uncertainty K] | 4.5 m/s² [1.5 m/s²] |
Vibration Cutting Wood [Uncertainty K] | 8.0 m/s² [1.5 m/s²] |
Voltage | 230 V |
