Makita SP6000J1 Plunge Saw & 2 x 1.5m Rails and Connectors
- Precise plunge saw with many features
- Supplied complete with Systainer case and 2x 1.5m guide rails
- Soft start and constant electronics
- Max depth of cut at 90° 55mm and at 45° 39mm
- Clear scale for precise saw adjustment
- -1° negative angle available, also pre-set 22.5°
- Can perform a cut 18mm from a wall
- Adjustment for perfect fit on rail
- Rail has anti-slip coating, so clamping not required
- 3 year Makita warranty available (registration required)
- Saw supplied in Systainer case with inlay, connector and fitted with 48t TCT blade
- Show More
Axminster Professional Quick Lever Guide Rail Clamp 160 x 60mmFrom £23.28 £19.40
UJK Dog Rail Clip (Pair)Special Price £7.99 £6.66 was £9.98 £8.32 Save £1.99 £1.66
Minimal tear-out, it’ll produce accurate cuts, each and every time.
If you need quick and accurate compound mitres or are looking to break down panels for carpentry, the Makita SP6000J1 Plunge Saw is the perfect choice.
Complete a range of cuts
In addition to performing plunge cuts, lengthways and crossways straight cuts and mitre cuts with angles in wood can also be performed while in firm contact with the workpiece.
Constant speed control
Thanks to the electronic speed control you’ll enjoy constant speed. The rotating speed is kept constant even under load conditions meaning it’s possible to get a fine finish.
Simple to adjust the depth of cut
For cleaner, safer cuts, you must set the cut depth so that no more than one blade tooth projects below your workpiece. Using proper cut depth helps to reduce the potential for dangerous kickbacks which can cause personal injury.
Speed adjusting dial
The blade speed can be adjusted by turning the adjusting dial. This is important to ensure the manufacturer’s recommended running speed is met. In general, higher speeds will allow you to cut workpieces faster. NB: If run at higher speeds than recommended, this can result in a poorer cut and compromise safety.
This plunge saw from Makita is supplied with 2 x 1.5m rails, connectors and storage case for the saw.
Why buy a plunge saw? Simple, it will allow you to cut a very precise straight line with ease and this saw is so well built with many features for the most precise cut when ripping and crosscutting.
The rail guides the saw perfectly, the rail has an anti splinter strip for a clean cut and the anti slip stips mean you do not even have to clamp the rail on most surfaces but additional rail clamps are available if required. The saw can also plunge for cut-outs if required. Driven by a powerful 1,300W motor (overload protected) with constant electronics to maintain speed under load for a very smooth cut. A variable speed dial allows you to select correct speed for material being cut. With a wide cut range and clear setting it can cut up to 55mm depth and 39mm at 45°, a 2mm scoring cut can quickly be made before the full depth cut, height and angles (-1° - 48°) are simply set with thumb screws, with positive stops for -1°, 22.5° and 45°.
This product is manufactured in the UK, at the Makita factory in Telford.
Supplied with 2 rails and connectors that have a replaceable splinter guard, anti-slip strips on the underside and top running strips for a smooth glide, 48T TCT blade and Systainer storage case with inlay.
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
- Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
- The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
Blade Diameter | 165 mm |
Bore Size | 20 mm |
Corded or Cordless | Corded |
Max Depth of Cut @ 45º | 39 mm |
Max Depth of Cut @ 90º | 55 mm |
Model | SP6000J1 |
Motor Power | 1,300 W |
Nett Weight | 4.2 kg |
Rating | Trade/Professional |
Saw Blade Speed | 2.000 - 5,200 rpm |
Sound Power Level LwA [Uncertainty K] | 102 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 91 dB(A) [3.0 dB] |
Spindle Lock | Standard Feature |
Vibration Cutting Wood [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
