Make your own pocket hole plugs. Simply use the plug cutter in a pillar drill to create you own plugs using matching or contrasting timber, glue them in, trim using a flush cut saw and sand to a finish. Cuts 9.5mm (3/8") diameter, plugs 55mm long. Maximum speed 700 RPM.
