UJK Professional Router Table
717127
From £899.98 £749.98
In Stock
  • Solid dependable router table
  • Top accepts the UJK router elevator plus a range of inserts
  • Quality one-piece aluminium fence
  • Sturdy leg stand with good mobility
  • Cast iron top for complete stability
  • Optional dust extraction box and router insert available
Solid and dependable
Repeatedly produce a professional standard of work with the UJK Professional Router Table
Comfortable control
The heavy duty cast iron table top is flex free and completely flat, minimising vibration and increasing stability. The stand has adjustable feet so you can achieve your ultimate working height.
Sturdy yet mobile
Made from 2mm thick plated steel, the stand is strong and rigid, yet the foot operated, retractable castor allows for easy mobility around the workshop.
Convenience built-in
The stand has a neat router cutter tray and a bracket for holding the supplied mitre fence assembly, meaning your attachments are always close to hand.
Reliable accuracy
The one-piece aluminium fence is meticulously straight and fits securely to the table.
Get even more from the UJK Router Table with these optional accessories
Take the chore out of changing the depth of cut with the UJK Router Elevator
Learn more
Quickly and easily cut a perfect mitre joint with the UJK Precision Mitre Gauge Fence & Flip Stop
Learn more
This professional router table is a solid, dependable unit that will give many years of useful service. The benefits of using cast iron for the manufacture of machine tables are well known, especially where vibration damping and stability are paramount. The quality of the surface grinding on this 815 x 615 x 40mm top is superb, offering little resistance when passing stock across the table during use. If you have room in your workshop for a full sized router table, you will wonder how you managed without one. There are many complex routing operations that can only be carried out using a table set-up. The aperture in the table tops is designed to accept our router elevator and when fitted with this unit you will have an excellent versatile set-up. Both tops feature a groove to accept a mitre fence attachment and are pre-drilled to accept the fence, leg stand and optional dust collection box.
The fence is a superb quality single aluminium section supplied with a transparent dust port for efficient extraction from above the table. Provision is made for the fitting of guards and accessories with a T-slot at both the top and front of the fence. An adjustable transparent guard is included for your safety. Adjustable scales are provided for attachment at either side of the table and the fence is attached to these and locks into place at the required position. A scale is also provided for the top of the fence with the zero position at the centre. Adjustable in-feed and out-feed fences attach to either side of the aluminium section and the central aperture can be opened and closed according to the diameter of the cutter in use. Fence measures 904 x 90mm high.
The UJK professional leg stand is of sturdy construction with a foot operated retractable castor for excellent mobility around the workshop. A neat rack is provided for keeping your most popular router cutters to hand and provision is made for storage of the supplied mitre fence assembly. Stand height approximately 890mm. Please note: there is an optional dust extraction box and router insert available.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.80 34
