UJK 10mm Aluminium Router Table Insert
105932
From £99.98 £83.32
  5. Half Star
11 Reviews
Low Stock - Ready to dispatch
  • UJK 10mm aluminium router table insert plate
  • Threaded lead-in pin
  • To fit 230 x 306mm aperture
  • Twist lock insert ring supplied with wrench
  • Range of central insert rings available
This 10mm aluminium insert plate for router tables measures 229 x 305mm and is designed to fit the UJK cast iron, phenolic or MDF router table tops. It is supplied with a removable central insert ring with a 38mm diameter hole with a range of other hole sizes available. This includes one that will accept a standard threaded guide bush for template routing. The insert plate will accommodate most portable routers and should be drilled to individual requirements.
4.70 11
