Axcaliber Contract 160mm TCT Saw Blades
- Generously sized tips brazed onto tensioned quality steel plates
- 160mm
- 2.2mm kerf
- 20mm bore
- Perfect for plunge action circular saws
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)From £18.28 £15.23
The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price. Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from handheld power tools right up to large panel saws used in production workshops, you will be certain to find a blade to suit every requirement. These 160mm blades are for handheld circular saws and have a thin kerf for lower power requirements. 20mm bore.
| Blade Diameter | 160 mm |
| Bore Size | 20 mm |
| Kerf | 2.2 mm |
| Maximum RPM | 10,000 rpm |
| Plate Thickness | 1.5 mm |
| Tooth Format | ATB |
Please note, respiratory items cannot be accepted for a refund once the seal is broken and the item has been worn.
