Axcaliber Dovetail Cutter Sets for UJK Jigs
- Matched pair, for use in the UJK Dovetail Jig
- Straight and dovetail cutter
- Diamond ground micrograin tungsten carbide tip
- PTFE coating helps cutter to remain free of resin
- 8mm, 1/4" or 1/2" shank
Axcaliber Dovetail Cutter Set - 1/2" ShankSpecial Price £18.13 £15.11 was £24.18 £20.15 Save £6.05 £5.04
Axcaliber Dovetail Cutter Set - 8mm ShankSpecial Price £16.49 £13.74 was £21.98 £18.32 Save £5.49 £4.57
These are a pair of matched cutters, one parallel and the other with a 7° dovetail slope. The pair can be purchased either with an 8mm, 1/4" or 1/2" shank and are intended to be used with the UJK Dovetail Jig. The cutting length of the straight cutter is 26mm and the dovetail measures 19mm.
