Axminster Engineer Series 17 Piece ER32 Precision Collet Set
- Collets grip over a diameter range of 1mm without loss of accuracy
- Arbors, collet nuts and wrench available separately
- ER32 collet holders have M12 threads
- Set of 17 comprises - 3 to 19mm
These end mill collets have the unique ability to grip over a diameter range of 1mm without any loss of accuracy. This flexibility means that fewer collets need to be stocked, making them a more economical proposition when compared to other collet-based systems. An additional benefit is that there is no requirement for a separate imperial listing; a 1/4" end mill, for example, will fit into the 7.00mm to 6.00mm collet. Collet nuts are available separately, ideal for customers wishing to make their own holding devices or spindles. ER32 collet holders have M12 threads. Set of 17 comprises - 3 to 19mm.
EAN Barcode | 5052511043989 |
ER Collet Series | ER32 |
Model | ER32 |
