Axminster Woodturning Straight Tool Rests
- The ideal support for all your turning tools
- 19mm diameter stainless steel round bar
- Tool glides smoothly along the length of the rest
- Tool rests are fully interchangeable with tool posts
- Available in lengths 100, 150, 250mm or 200mm long reach.
- Requires tool post, purchased separately
Axminster Woodturning Tool Post - 25.4mm (1") x 128mmSpecial Price £9.79 £8.16 was £13.98 £11.65 Save £4.19 £3.49
Axminster Woodturning Tool Post - 16mm x 110mmSpecial Price £6.14 £5.12 was £8.78 £7.32 Save £2.64 £2.20
For the smoothest turning
The Axminster Woodturning Tool Rest System is made entirely of stainless steel which means it's corrosion and rust free. The chisel glides seamlessly across the rounded bar without any nicked interruptions.
There are two simple steps...
The stainless steel round bars form the perfect tool rests and screw into the posts. Choose a selection of straight and curved rests - plus a mounting plate - to suit all your turning projects. Each of the accessories will fit a single tool post so it's easy to swap between them as you turn!
Axminster Woodturning Traditional Tool Rests are also available. These feature a large, round, hardened steel bar which is welded on top of a cast steel rest.
1. Select a post
Choose a diameter to suit your lathe
- 12mm x 81mm long
- 16mm x 110mm long
- 19mm x 115mm long
- 25mm x 140mm long
- 25.4mm x 128mm long
- 25.4mm x 180mm long
- 30mm x 180mm long
2. Choose your rests or mounting plate
- 100mm - for working in confined spaces, ideal for box making
- 150mm - a middleman for general size turning!
- 200mm - for gaining more access and supporting the chisel when turning deep inside vases and other hollow forms
- 250mm - long length allows for deep support for the chisel inside bowls or longer pieces between centres
- 300mm - available in the Axminster Woodturning Traditional Tool Rest range
- S Shaped - gain greater control and get closer to the bowl when turning
- Mounting plate - useful for when you're carving, drilling, finishing etc
Your tool rest is the point of contact between you, the lathe, the tool and the work. It is important that the tool has the smoothest possible transit along the rest. Any bumps, ridges or hollows soon take the pleasure out of turning. Most standard tool rests are cast iron or relatively soft steel. These rests can soon develop nicks along their length and require occasional draw filing to bring them back into a usable condition. The Axminster Evolution Tool Rest System overcomes this problem.
In order to make the system as economic as possible, Axminster Evolution produces the tool rests and tool posts as separate items. Before selecting a tool rest you need to purchase a tool post. The tool rest screws onto the tool post. A single tool post will fit any of the four lengths of tool rest. Additional tool rests simply screw onto the same tool post. If you own a second lathe requiring a different diameter tool post, then the purchase of a second tool post allows you to use all your existing tool rests. Spanner flats ground onto the tool post help fitting or removing the tool rest.
A 19mm diameter stainless steel round bar forms the perfect tool rest. This simple design overcomes all the disadvantages encountered with standard tool rests and has additional benefits. The tool glides smoothly along the length of the rest. The round profile gives more control when changing the angle of the tool in the vertical plane. Using stainless steel means corrosion and rust are a thing of the past.
Tool rests are available in 100mm, 150mm, 250mm lengths or a 200mmm length long reach tool rest, for gaining access more easily when turning vases and other hollow forms. Once screwed onto your tool post, these two parts form the ideal support for all your turning tools.
