Axminster Model Engineer Series C0 Micro Lathe
- Cast iron with ground, hardened slideways
- Belt driven, with electronic variable speed
- Fitted with 50mm self-centring 3-jaw scroll chuck
- Chuck guard with a safety interlock
- 125mm between centres and a swing diameter of 110mm
- Supplied with wrench set
Axminster Model Engineer Series C0 Woodturning Tool RestFrom £45.58 £37.98
Axminster Model Engineer Series C0 Revolving Tailstock CentreFrom £27.48 £22.90
Axminster Engineer Series 11 Piece Tungsten Carbide Lathe Tool SetFrom £27.48 £22.90
Axminster Model Engineer Series Top Slide for C0 Micro LatheFrom £39.68 £33.07
A high quality, miniature metalworking lathe, constructed to a very high standard around a cast iron, hardened and ground bed. The spindle is powered by a 150W motor through a variable speed drive giving spindle speeds of 100-3,850rpm. With a swing of 110mm and 125mm between centres, this is an ideal machine for making small parts for models and integrating metal parts into woodturning projects etc. Weighing only 13kg, this is a very portable but capable machine. It is fitted with a 3-jaw self-centring chuck with reversible jaws, single tool post taking 8mm tooling, splash guard and interlocked chuck guard for safety. The spindle thread is 14 x 1mm and has a 10mm bore.
Axminster Model Engineer 3 Year Guarantee
Machine Classification
These products are designed and intended to be used in the home for light work and not for continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or education purposes.
Centre Height | 55 mm |
Chuck Fitting | M14 x 1 |
Cross Slide Travel | 50 mm |
Distance Between Centres | 125 mm |
EAN Barcode | 5052511060863 |
Headstock Taper | Straight bore |
Height Over Cross Slide | 58 mm |
Max Diameter over Bed | 110 mm |
Model | SIEG C0 |
Nett Weight | 13 kg |
Overall L x W x H | 440 mm x 270 mm x 210 mm |
Plug Fitted | UK 3 pin plug |
Power | 150 W |
Rating | no value |
Spindle Bore | 10 mm |
Spindle Speed | 100 - 3,850 rpm |
Tailstock Ram Travel | 25 mm |
Tailstock Taper | Straight bore |
Tool Shank Size | 8 mm |
Voltage | 230 V |
