Axminster Model Engineer Series SX2 Mini Mill
505099
From £1,039.98 £866.65
In Stock
  • Constructed in cast iron for vibration free running
  • Ground and hardened slideways with gib strip adjustment
  • Milling head and column tilts to 45° left & right
  • 500W high torque DC brushless motor with belt spindle drive
  • Fine down feed control for accurate tool height setting
  • Coarse down feed for drilling operations
  • 3MT spindle fitted with a 13mm drill chuck and arbor
  • 13mm drilling, 16mm end milling and 30mm face milling capacity
A fine, high precision mill/drilling machine, an ideal companion to the SC2 lathe. Constructed in cast iron with a finely ground table with 12mm T slots, and ground and hardened slideways. The milling head and column can tilt to 45° left or right for compound angle milling or drilling. The ample power comes from a high torque, brushless 500W DC motor with variable speed, giving a spindle speed range of 100 - 2,500rpm. It also has a notably quiet running spindle belt drive system. The spindle has an internal 3MT bore to enable a large range of tooling to be used. The headstock quill has a fine downfeed control feature for milling and a rack and pinion downfeed system for drilling. A gas support strut holds the headstock in position. The table leadscrews are covered for protection against swarf and debris. There is a connection port on the headstock for the optional digital spindle speed display panel. Supplied with a drill chuck and arbor, safety guard, tools and three drawbars 10mm, 12mm, 3/8 Whitworth. This is a superb, small mill for the model engineer.
Warranty Model Engineer Classification & 3 Year Guarantee
Axminster Model Engineer 3 Year Guarantee
Machine Classification
These products are designed and intended to be used in the home for light work and not for continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or education purposes.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.50 13
