Axminster Woodturning Diamond Parting Tool - 3.2mm(1/8")
- HSS offers excellent edge holding properties
- Good width for sizing your spindle work and parting off
- Diamond section blade offers increased clearance during cut
Axminster APF 10 Evolution® Powered Respirator with Impact VisorFrom £299.98 £299.98
Premium’s the name, quality’s the game
When it comes to quality Axminster Woodturning is a name you can trust for all your turning tools and none can compare to those in our Axminster Woodturning Premium range.
What’s in the range?
Designed in Axminster, and crafted in Sheffield, the Axminster Woodturning Premium range really is a cut above the rest. Super strong, and made to last, all blades in the Premium Range are manufactured from M2 high speed steel to retain a sharp edge and leave a smooth finish.
Axminster Woodturning Premium Standard Skew
- 19mm (3/4")
Give a smooth surface to your spindle turning via planing cuts using this standard skew chisel. It can also be used for producing details such as V cuts and beads.
Axminster Woodturning Premium Spindle Gouge
- 6.3mm (1/4")
- 9.5mm (3/8")
- 12.7mm (1/2")
Use the spindle gouge for creating curved detail on spindle projects, either in concave or convex form.
Axminster Woodturning Premium Spindle Roughing Gouge
- 19mm (3/4")
The workhorse of the spindle turner’s tool kit is the spindle roughing gouge. Use it to square stock down to round, or simply to take away bulk.
Axminster Woodturning Premium Diamond Parting Tool
- 3.2mm (1/8")
An essential part of the spindle turner’s tool kit, the parting tool is used for parting off, sizing and side scraping.
Axminster Woodturning Premium Bowl Gouge
- 6.3mm (1/4")
- 9.5mm (3/8")
- 12.7mm (1/2")
The bowl gouge is essential for bowl turning or faceplate projects.
Axminster Woodturning Premium Beading and Parting Tool
- 9.5mm (3/8")
Use for bead forming via rolling cuts and great for practicing the art of bead rolling before moving onto the skew chisel. The beading and parting tool, can also be used for sizing and creating tenons.
Axminster Woodturning Premium Square End Scraper
- 19mm (3/4")
Used for finishing convex and flat bottomed forms, the square end scraper is the ideal tool to give perfectly flat bottoms on the insides of boxes.
Axminster Woodturning Premium Round Nose Scraper
- 12.7mm (1/2")
Create smooth flowing curves on the inside of bowls and platters with the round nose scraper.
A diamond parting tool offers more clearance during deeper cuts minimising heat build-up and lessens the need to make the cut wider. Made in Sheffield for Axminster by skilled craftsmen using traditional skills with modern heat treatment and finishing techniques. The blades are M2 high speed steel known to hold its edge and retain its hardness at high temperatures and will give a clean smooth finish. We have added a 300mm dyed beech handle. Will suit the beginner, amateur or professional turner.
EAN Barcode | 5052511088423 |
