Axminster Professional Bar & G-Clamp Racks Package
720588
From £34.98 £29.15
13 Reviews
  • Extra heavy 2mm thick steel, tough painted finish
  • Pre-drilled for wall mounting
  • Axminster Professional Bar Clamps Rack
  • For F clamps, sash, bar or parallel jaw clamps etc
  • Organises unruly long clamps
  • Holds 12 clamps or up to 25kg load capacity
  • 12mm wide slots, for easy retrieval
  • Axminster Professional G Clamps Rack
  • Holds 10 G clamps
  • Suitable for any size G clamp from 75m to 250mm
  • Quick and easy access to clamps
  • Show More
See the entire range
Fed-up with always having to disentangle the G-cramp you need from the heap, or do all your sash cramps topple over everytime you take one from the stack? Here’s a way to solve both problems at once and maybe free up some workshop space at the same time.
The Bar clamp rack will deal with your storage problem in the best possible way. It will safely store your F-clamps, sash clamps and parallel jaw clamps. The storage slots are 12mm wide and the rack has space for up to 12 clamps or 25kg in weight. Made of 2mm thick steel with a tough painted finish, each rack is 590mm long and pre-drilled for fixing on to a wall. Say goodbye to that heap of clamps in the corner.
The G-clamp rack provides space for up to 10 of your best G-clamps. Being wall mounted, your clamps will sit neatly out of harm's way waiting for the next time you need them. Slots in the rack ensure quick and easy access for sizes from 75mm to 250mm. The 2mm thick steel has the same painted finish as the Bar clamp rack. It measures 420mm long by 70mm high.
Warranty Axminster Professional Clamps Lifetime Guarantee
British Made British Made
4.80 13
