Axminster Professional Guide Rail Clamps (Pkt 2) -160 x 60mm
719098
From £23.95 £19.96
28 Reviews
  • Please check your guide rail prior to ordering
  • Spigot 11 mm wide, 7.5 mm thick, 60 mm long
  • Fits Festool FS, Makita and many other extruded guide rails
See the entire range
An F-clamp with a specially designed head that fits into the slot of power tool guide rails. It is compatible with the Festool FS and Makita guide rail system and many others. The clamp has a capacity of 120 mm and a plastic pad on the swivel shoe to protect the work surface.
Please check the clamp slot in your guide rail prior to ordering. The spigot is 11 mm wide by 7.5 mm thick and 60mm long. Sold as a pair.
Warranty Axminster Professional Clamps Lifetime Guarantee
4.90 28
