UJK Air Wedge - Slim 100mm
- Inflatable shims with dozens of uses
- For fitting, fixing or levelling; slimline, slides into a 2mm gap
- Hand operated for controlled inflation
- Hard-wearing, non-marring material
- Sealed and glued with TPU and high frequency welding
- Slim: size 100mm x 140mm, lift 2mm to 45mm
UJK Air Wedge - Wide 260mmSpecial Price ÂŁ14.98 ÂŁ12.48 was ÂŁ19.68 ÂŁ16.40 Save ÂŁ4.70 ÂŁ3.92
Axminster Workshop 19 Piece High Speed Steel Ground Drill Bit SetFrom ÂŁ19.58 ÂŁ16.32
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price ÂŁ79.63 ÂŁ66.36 was ÂŁ89.98 ÂŁ74.98 Save ÂŁ10.35 ÂŁ8.62
The UJK Air Wedge uses the same principle that air-jacks use to lift large commercial vehicles weighing many tons.
Versatile doesn’t even begin to describe the UJK Air Wedge. Whether you are fitting, fixing or levelling, the UJK Air Wedge makes the job a great deal easier. The UJK Air Wedge is good for lifting something up, pushing something into position or forcing things apart. Made from highly durable, non-marring material and with triple welded seams, the UJK Air Wedge is virtually indestructible. An internal stiffener makes it easy to insert the UJK Air Wedge into a narrow gap. By gently squeezing the bulb, you can make controlled, fine adjustments. Press the release valve to deflate the Air Wedge.
Initially marketed as a tool for holding window frames in place prior to fixing, it is indispensable in many other situations. When fitting a door, a UJK Air Wedge underneath one corner makes it easy to align the hinges. For levelling kitchen appliances or cabinets, use a UJK Air Wedge to lift a fridge or washing machine etc while you make adjustments.
Slim: size 100mm x 140mm, lift 2mm to 45mm, maximum lifting weight 100kg.
EAN Barcode | 5052511101726 |
