Axminster Professional One Handed Clamp
- Glass fibre reinforced jaws and strong 20mm x 6mm steel bar
- Simply squeeze the handles to operate
- Throat depth 85mm, tough, non-marring jaw pads
Titebond III Waterproof Wood Glue - 3.8litres (1 US Gall)From £69.98 £58.32
UJK Air Wedge - Slim 100mmSpecial Price £10.38 £8.65 was £15.98 £13.32 Save £5.60 £4.67
See the entire range
With glass fibre, reinforced jaws and a strong 20mm x 6mm steel bar, these clamps perform well. The biggest advantage is their simple, single-handed operation, leaving one hand free to steady the work. Simply squeezing the handles to operate the clamp, results in great control. They have non-slip inserts and the rear handle houses the release trigger. An easily operated locking mechanism on the fixed jaw, locks or unlocks the jaw to convert the clamp into a spreader. The jaw pads are tough and non-marring with a little ‘give’ to grip irregularly shaped work. All sizes – 100kg max clamping pressure
Lifetime Guarantee.
