Axminster Professional Twist & Fix 100mm Felt Wheel - Hard
105580
105580
From £16.98 £14.15
4 Reviews
  • Hard felt for straight edge tools, razor-edge results every time
  • Felt wheels produce the ultimate, mirror polished edge
  • Mounts directly onto the Ultimate Edge 'Twist & Fix' arbor
  • Use with honing compound
  • 100mm diameter x 20mm wide, 12mm bore
Use these felt wheels to produce the ultimate, mirror polished edge. The finest edge you can get on any tool is with a strop or a felt wheel. Made from compressed wool, felt wheels have excellent resilience and are long lasting.
Hard felt is the better choice for finishing the bevel on a plane iron or bevel edge chisel. The hard face of the wheel ensures even polishing of the flat bevel without rounding over the edge.
When the wheel is dressed with a honing compound, the edge obtained is comparable to a razor blade. For best results use with Blue Steelbrite, Flexcut gold or Veritas green compound.
Each 100mm diameter x 20mm wide wheel has a 12mm bore for mounting onto the Ultimate Edge Twist & Fix arbor.
Please note that blades should always be presented to the wheel so the edge of the tool trails, i.e. the direction of rotation is away from the tool.
British Made British Made
5.00 4
