Bosch EasyImpact Cordless Combi Drill 18V 1.5Ah
- Versatile for drilling, screwdriving and impact drilling
- Compact, ergonomic and practical
- 2-speed gearbox and 20 torque settings
- Built-in LED lighting illuminates working area
- POWER FOR ALL ALLIANCE battery
- Battery compatible with many other tools and brands
- Supplied with 1.5Ah Li-Ion battery Charger and storage case
The versatile EasyImpact 18V-40 will cope with the vast percentage of your drilling and screwdriving needs. From the Bosch green staple of power tools, this cordless combi features a 2-speed gearbox and 20 torque settings. Plenty of speed for drilling and plenty of power for screwdriving. The single sleeve 13mm keyless chuck makes changing bits easy.
The drill is compact and thoughtfully designed for comfort and practicality. The built-in LED lighting takes the strain out of working in dark spots. The EasyImpact 18V-40 is a capable all-rounder for drilling in wood, masonry, metal, plastic, and for screwdriving.
The tool belongs to the POWER FOR ALL ALLIANCE. One battery can operate a large variety of tools from different brands.
POWER FOR ALL; means one battery and charger covers an entire Home & Garden tools system.
Supplied with 1.5Ah Li-Ion battery Charger and storage case.
This applies to all DIY power tools, garden tools or measuring tools from Bosch. This tool comes with a FREE two-year warranty, to extend your warranty to three years, simply log into MyBosch. and register your tool within four weeks of purchasing it.
Extended warranty includes: repair service, pick-up and returning your defective device for free. Warranty services are all provided by Bosch directly.
To register your tool, please visit MyBosch.Batteries Included | 1 |
Battery Capacity | 1.5 Ah |
Battery Type | Li-ion |
Battery Voltage | 18 V |
Chuck Capacity | 13 mm |
Chuck Type | keyless |
Corded or Cordless | Cordless |
Drilling Speed | 0 - 430 rpm / 0 - 1,630 rpm |
Impact Rate | 0 - 24,450 /min |
Max Drilling Masonry | 13 mm |
Max Drilling Metal | 13 mm |
Max Drilling Wood | 30 mm |
MPN | 06039D8107 |
Nett Weight | 1.3 kg (with battery fitted) |
Rating | Home Workshop |
Reverse | Standard Feature |
Sound Power Level LwA [Uncertainty K] | 97 dB(A) [5.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 86 dB(A) [5.0 dB] |
Torque | 40 Nm |
Torque Settings | 20 + Drilling |
Vibration Drilling Concrete [Uncertainty K] | 25.0 m/s² [3.0 m/s²] |
Vibration Drilling Metal [Uncertainty K] | <2.5 m/s² [1.5 m/s²] |
Vibration Screwdriving [Uncertainty K] | <2.5 m/s² [1.5 m/s²] |
