The Bosch Universal Sander 18V-10 comes with two bases. The pointed one allows easy access into corners, whilst the rectangular base helps when sanding large areas. Changing bases is quick, simple and toolless with the SDS click system. The battery position and large top grip make the 18V-10 well balanced and easy to manoeuvre. The sander includes an efficient micro filter dust box to help keep your working environment clean. Alternatively, the sander can be hooked to a vacuum.
Variable speed selection enables you to match the speed, abrasive and material for the best result. A hook and loop system for attaching the abrasive is not only quick, it allows you to save and reuse the abrasive at a later date.
Fitted with Syneon Technology, which ensures you get the optimum run time from the battery.
Note: this is a body only tool supplied without battery or charger.
The good news is, it’s part of the POWER FOR ALL battery system from Bosch. It is compatible with the 18V batteries from any of the tools in the Bosch POWER FOR ALL FAMILY Home and Garden range.
This applies to all DIY power tools, garden tools or measuring tools from Bosch. This tool comes with a FREE two-year warranty, to extend your warranty to three years, simply log into MyBosch. and register your tool within four weeks of purchasing it.
Extended warranty includes: repair service, pick-up and returning your defective device for free. Warranty services are all provided by Bosch directly.
