The GSS 18V-10 is Bosch’s first cordless orbital sander. This orbital palm sander offers great flexibility thanks to 3 different exchangeable bases. It comes with 1/4 sheet square, 1/6 sheet rectangular and delta sanding bases; whatever the job you will have the right base. In effect, the GSS 18V-10 is 3 sanders in 1. It is smaller than the comparable corded sander and has all the benefits of cordless. There are no cables dragging across the surface of sensitive materials. The lightweight and compact design makes it ideal for use overhead or in difficult-to-reach places. Thanks to the ergonomic shaped top with soft grip, it is easy to manipulate in different positions with complete single-handed control. A Bosch microfilter box offers efficient dust extraction. Alternatively, you can connect to a vacuum extractor. Abrasive sheets use the “Easy Fit” clamping system or hook and loop backed abrasive, depending on the baseplate. Taking all the features into account, this 18V tool from Bosch is as close as you can get to the ultimate palm sander. The GSS 18 V-10 increases the Bosch 18V Li-ion range to well over 40 tools.
Part of the multi-brand AMPShare battery system, offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Fein and Bosch Professional 18V tools and chargers all the way back to 2008.
Supplied with Delta baseplate (100 x 150mm), 1/4 sheet baseplate (113 x 101mm), 1/6 sheet baseplate (80 x130mm), 1/4 sheet hole-punch, microfilter box, 3 sanding sheets and L-BOXX 136 storage case.
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
