Crown Cryo Parting & Beading Tools
AX946402
AX946402
- Standard diamond and beading/parting designs
- Double bevelled cutting edges
- 215mm(8.1/2") long handles
- Cryogenic HSS blades
Hermes RB 406 J Flex Ultimate Abrasive 100mm x 1m (Pkt 5) - MixedFrom £30.98 £25.82
Axminster APF 10 Evolution® Powered Respirator with Impact VisorFrom £299.98 £299.98
Show more
Show less
A range of cryogenic HSS parting tools of the standard diamond and beading/parting designs, all with double bevelled cutting edges. The standard ones are rectangular in section and 12.7mm(1/2") deep; the diamond ones are relieved on the sides to reduce jamming in the cut whilst the beading and parting versions are square in section to allow for easier access around beads and other small details. Handle lengths are 215mm(8.1/2").
British Made
