Easy Wood Tools Full-Size EASY FINISHER™
- Ideal for spindles, table legs, large bowls, platters etc
- Finisher for coves, hollows, sweeping curves and final shaping
- No need to sharpen; simply rotate cutter to a fresh edge
- Solid carbide tip keeps an edge many, many times longer than HSS
- Use to turn dry or green wood, acrylics and resin
- 12.7mm square section bar ensures the tool sits flat and steady
- American Maple handle with copper ferrule for strength
- Easy Wood Tools are 100% made in the USA
Easy Wood Full-Size Easy Tools are ideal when it comes to turning spindles, table legs, large bowls and other similar projects. He longer handle offers greater control when working on larger projects
Use the Easy Wood Full-Size Easy Finisher for making coves, hollows, sweeping curves and final shaping. It comes fitted with a round tip and includes a hex key for the mounting screw. The 406mm long handle is American Maple with a copper ferrule for strength (the tools have different coloured handles for easy recognition). The 12.7mm square section bar ensures the tool sits flat and steady on the tool rest. With the tool parallel to the floor and cutting at centre height the risk of catches and snatches is virtually eliminated. You don’t need to sharpen these tools. When an edge becomes dull you simply slacken the fixing screw and turn to a fresh edge. Easy Wood Tools’ carbide keeps an edge many, many times longer than HSS. These tools can be used to turn dry or green wood and acrylics.
Overall length of 622mm. The shaft is engraved with the corresponding carbide cutter reference number.
