Easy Wood Tools Mid-Size EASY FINISHERâ„¢
109311
From £111.48 £92.90
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • The perfect go-to tool for bowls, platters, boxes and spindles
  • Finisher for coves, hollows, sweeping curves and final shaping
  • No need to sharpen; simply rotate cutter to a fresh edge
  • Solid carbide tip keeps an edge many, many times longer than HSS
  • Use to turn dry or green wood, acrylics and resin
  • 9.5mm square section bar ensures the tool sits flat and steady
  • American Maple handle with copper ferrule for strength
Go-to tools for any turner
A versatile set of tools for a range of turning projects. Whether it bowls, platters or boxes, the Easy Wood Mid-Size range is the perfect go-to tool to keep your turning on track
  • Handles are made from one-of-a-kind grained American Maple and feature a copper ferrule for strength
  • All tools come with a fresh standard carbide cutter installed, and a hex key that fits the mounting screw
  • The range features three cutting types with colour coded handles to make your turning easy from start to finish
Mid-Size Easy Rougher
Remove bulk material quickly and efficiently.
Mid-Size Easy Finisher
For creating curves and for final shaping.
Mid-Size Easy Detailer
Create fine details such as small coves and beads.
Mid-Size Micro Easy Detailer
For precision details - micro coves, beads, and finer details.
Why buy?
All tools come with a carbide cutter and hex key. These cutters retain their edge with no need for regular resharpening. When one edge does dull, simply flip the cutter and finally replace when needed. A range of optional cutters and replacement cutters are available too.
Easy to use
All Easy Wood Tools are held flat to the tool rest and parallel to the floor making them much easier to use than traditional tools.
Never sharpen again!
The premium grade carbide tipped cutters last at least ten times longer than HSS (High Speed Steel) before dulling. Meaning you can turn time and time again, with no need to sharpen.
Replace your cutters
When your edge finally dulls, simply replace it. All tool shafts are engraved with the corresponding engraved cutter number to make replacing cutters simple. See the range of cutters
Quality from end to tip
All carbide cutters feature the best grade carbide for lasting sharpness and a precision grind for a smooth and optimum edge for your turning.
Easy Wood Mid-Size Easy Tools offer great versatility when it comes to turning bowls, platters, boxes, and other projects. These are the perfect go-to tool.
Use the Easy Wood Mid-Size Easy Finisher for making coves, hollows, sweeping curves and final shaping. It comes fitted with a round tip and includes a hex key for the mounting screw.
The 350mm long handle is American Maple with a copper ferrule for strength (the tools have different coloured handles for easy recognition). The 9.5mm square section bar ensures the tool sits flat and steady on the tool rest. With the tool parallel to the floor and cutting at centre height the risk of catches and snatches is virtually eliminated. You don’t need to sharpen these tools. When an edge becomes dull you simply slacken the fixing screw and turn to a fresh edge. Easy Wood Tools’ carbide keeps an edge many, many times longer than HSS. These tools can be used to turn dry or green wood and acrylics.
Overall length of 533mm. The shaft is engraved with the corresponding carbide cutter reference number.
