Festool HKC 55 EB Li-Basic Cordless Circular Saw 18V (Body Only)
- Basic machine without batteries and charger
- 55mm depth of cut, rip or cross cut
- Makes plunge cuts to an exact depth easily and conveniently
- FastFix blade change for quick, one-handed tool-less changing of the blade
- Hinged blade cover allows clear blade and cut line visibility
- Compatible with Festool FSK and FS guide rail systems for ultimate versatility
- 3 year Festool warranty available (registration required)
- Supplied with 18 tooth blade and SYS 4 T-LOC SYSTAINER
Exhibiting the true capabilities of an innovative, cordless circular saw
Wherever you require repeatable angled cuts, this capable and impressive circular saw will always make the cut. With the option to add a guide rail, its versatility is unmatched.
Powerful EC-TEC motor
Thanks to the impressive EC-TEC motor, you can achieve perfect results, faster. Delivering more than enough power for its 55mm maximum depth of cut, the HKC 55 will help you to be unstoppable. Extremely robust, the brushless motor requires less maintenance, resulting in an extended battery life. Whilst packing plenty of power, the motor doesn’t use a lot of energy to deliver this, so you’ll be good to go all day.
Excellent cutting performance
An ideal companion for rip or cross cuts. The HKC 55 saw can make achieving precise plunge cuts, look easy. Simply push the lever and set the desired cutting depth using the clearly visible and easy-to-read scale, then release. It’s so easy to reach the exact depth, easily and conveniently.
Festool’s FastFix blade change feature allows for quick, one-handed changes, without the need for additional equipment or manual tool changes. Festool always think of the user and how they can make the job less time-consuming. When a job requires quick tool changes, this feature is saves time and improves the quality, by working with a blade that’s matched to the material. A hinged blade cover allows clear blade and cut line visibility.
Even more versatility
More independence calls for more precision and the possibilities are endless, with such a capable machine such as this. Elevate your projects to new heights, working from a roof? The FSK Cross-cut Guide Rail will help demonstrate this ascend with ease. Available in three lengths and easy to set up; you’ll have a mobile compound mitre saw system for accurate angled cuts to-hand whenever you need it.
Bluetooth compatibility
Clever as a system, the Li-HighPower compact battery available, includes the latest Bluetooth technology. Festool always thinks of the small details that make a big difference. The battery communicates with a Festool mobile dust extractor fitted with a bluetooth receiver. The benefit? It switches on and off, in accordance with the cordless tool that it is paired with. Saving you time and effort.
Convenient and safe
Handle this machine safely, thanks to the cutting depth adjustment with plunge-cut function, remote control of the suspended cover and guide wedge angle adjustment from 0 to 50°.
MyFestool
For your added support, Festool offers a comprehensive service plan once you register your tool. Enjoy the following benefits with the Warranty all-inclusive:
- Free repairs for three years
- Fast resolution directly from Festool
- Replaced in the event of theft
Part of the faultless Festool system
The 18V cordless lineup from Festool is quite simply brilliant. Always thinking of all the small details, Festool helps you achieve tasks more efficiently, and with plenty of power. Whatever your project demands, this range will most likely have the tool for it.
For owners of other Festool 18V system tools, the HKC 55 comes as a basic machine, without batteries and charger. The HKC 55 gives you precision coupled with independence. The EC-TEC brushless motor delivers more than enough power for the saw’s 55mm maximum depth of cut. The HKC 55 is ideal for rip or cross cuts. The HKC 55 saw can make plunge cuts, simply push the lever and set the desired cutting depth using the clearly visible and easy-to-read scale, then release. You can make plunge cuts to an exact depth easily and conveniently. The FastFix blade change allows quick, one-handed tool-less changing of the blade, saving time and improving quality by working with a blade matched to the material. A hinged blade cover allows clear blade and cut line visibility. The HKC 55 becomes even more versatile when combined with an FSK cross cut guide rail or FS1400/2 guide rail.
Supplied with 18 tooth blade and SYS 3 M 337 T-LOC SYSTAINER
Benefits
- Includes 36 month machine guarantee
- Full repair, free of charge
- Original parts guaranteed
- 14 day money back
Batteries Included | Body Only Tool |
Battery Type | Li-ion |
Battery Voltage | 18 V |
Blade Diameter | 160 mm |
Bore Size | 20 mm |
Corded or Cordless | Cordless |
Dust Extraction | 27 mm / 36 mm Outlet |
Max Depth of Cut @ 45º | 42 mm |
Max Depth of Cut @ 90º | 55 mm |
MPN | 577232 |
Nett Weight | 4.1 kg (with 5.0Ah battery) |
Rating | Trade/Professional |
Saw Blade Speed | 4,500 rpm |
Sound Power Level LwA [Uncertainty K] | 105.7 dB(A) |
Sound Pressure Level LpA [Uncertainty K] | 79 dB(A) [3.0 dB] |
Vibration Cutting Wood [Uncertainty K] | 2.5 m/s² [3.0 m/s²] |
