Festool RG 130 ECI Surface Restoration Grinder 230V
- Designed for hard material removal, surface preparation
- Effective on concrete, screeds, plaster, old tile cement etc.
- 1,600W EC-TEC motor with constant electronics
- Flip-up front section allows work against a wall
- Adjustable depth guide for controlled removal
- Efficient dust extraction with brush seal around disc
Removing lumps and bumps from concrete is never an easy job. The RENOFIX RG 130 ECI Surface-restoration grinder is the answer. This machine enables you to rapidly flatten concrete surfaces or screeds, remove plaster, old tile cement, paint, glue residues and coatings. A 130mm diameter flat diamond disc (sold separately) effectively grinds the surface away. There are a number of types of disc available to suit the surface material or finish required.
The RENOFIX RG 130 ECI is fitted with a brushless EC-TEC motor offering high efficiency, high material removal and fast progress. Variable speed gives flexibility for matching speed to a variety of materials. An adjustable depth guide ensures an even surface finish removing no more than is necessary. A flip-up front piece allows you to work right up to a wall, the whole job can be done with this one tool.
The grinder comes with Bluetooth® connection allowing a compatible extractor to be started automatically if the RG 130 ECI is inserted into a separate electricity source.
The machine is for dry use only and a connection to a suitable vacuum extractor (M-class) is most important. The design of the discs combined with an outer brush ring means, when connected, dust extraction is very effective, leaving the working environment cleaner and minimising clean-up.
Supplied with front handle, brush ring, depth flange, spanner, 5 hook and loop fasteners and Systainer SYS3 L 237.
Discs sold separately.
