Festool Sabre Saw Blade Carbide Demolition DHMR230 (Pkt 1)
- Carbide tipped for maximum working life
- Extremely strong, extremely durable
- Made for extreme usage
- Universal fitting
If you need to do some demolition this is the blade you need. Extremely strong, extremely durable made for extreme usage. This blade features carbide tipped teeth and a reinforced design for use when dismantling and demolition work. The progressive tooth pitch offers long working life even when cutting different thicknesses and types of material. Use these blades for cutting wood with nails and screws (hardened), dismantling window and door frames, cutting wood with mortar residue. dismantling drywall, cast iron, glassfibre and general demolition work.
The blades feature the universal shank fitting, suitable for use in the majority of sabre saws.
