Festool Sabre Saw Blades Universal HSR230 (Pkt 5)
- Tough, cut solid wood with nails
- Bi-metal, wear resistant for long life
- Versatile suitable for a wide variety of materials
- Cross-set teeth for fast cutting
- Flexible for flush cutting
- Universal shank fitting
Tough blades for tough jobs. These bi-metal blades are designed to cut a wide variety of materials. Wear-resistant for a long life, they are ideal for demolition work where there is the possibility of encountering hidden metal such as nails. The high speed steel edge material makes them temperature-resistant and suitable for cutting fibreglass, epoxy, plastics, non-ferrous profiles and all timber and manmade wood materials. The maximum cutting depth is 205mm. Deeper gullets every fifth tooth speed up waste clearance for faster progress. The blades feature the universal shank fitting, suitable for use in the majority of sabre saws.
