Flexcut Carvin' Jack 2.0
- A complete carving kit in your pocket
- Carve any time and wherever inspiration strikes
- 6 different super sharp carving blades
- Comfortable contoured aluminium body
- Supplied with SlipStrop honing block and Flexcut Gold
- Includes Leather holster for safe storage
Boasting six different carving blades, weighing in at a mere 125g and only 108mm long, the Flexcut Carvin' Jack 2.0 is practically a complete carving kit in your pocket. Perfect for carving wherever and whenever inspiration strikes.
The Flexcut Carvin' Jack 2.0 is designed specifically for the needs of woodcarvers. The blades include: a Detail Knife, a Pelican Knife, a Hook Knife (Radius = 19mm), a Straight Gouge, a Gouge Scorp, and a V-Scorp.
It is available in two versions, either right or left-handed. The choice is governed by how you carve, not necessarily whether you are right or left-handed. Choose a right-handed knife if you are right-handed and carve with the blade away from yourself. If you carve towards yourself choose a left-handed knife. Left-handers should choose the opposite.
The Carvin' Jack 2.0 is the ultimate for portability. The 2.0 version has a comfortable contoured aerospace aluminium body, cross hatched for a secure grip and greater carving control.
Supplied with SlipStrop honing block and Flexcut Gold polishing compound to keep in tip-top carving condition.
Full instructions included.
