The Fuji Spray LX-20™ is a general purpose HVLP spray gun perfect for all types of professional spray finishing. It can handle with ease all types of coatings including high solid materials. This spray gun is designed for use in a production setting.
The LX-20™ spray gun has been designed to replace conventional high pressure spray guns. It is supplied as a gravity feed model with a 600cc cup. Fuji Spray HVLP compressor spray guns are well known for higher transfer rates. It is especially suited to wood finishing and any fine finishing application.
The gun is compact, lightweight and easy to handle. The ergonomic design allows the spray gun to feel comfortable in the user’s hand for extended periods of time.
The LX-20™ is also easy to operate employing the same familiar controls as any conventional spray gun. The fan pattern control offers precise adjustment reducing overspray and waste. Fan pattern size is adjusted with a simple, yet effective side mounted control. At a spray distance of 8” the fan pattern size ranges up to 13”.
Supplied with a fitted 1.4mm air cap; 1.2mm and 1.7mm air caps are also included in the kit.
Fuji Spray LX-20™ HVLP technology complies with environmental regulations for HVLP. The added benefit provides considerable savings in material compared to conventional high pressure spraying equipment. LX-20™ technology also allows for little to no dilution for most coatings. This allows for spraying finishes as per the manufacturer’s recommendation. The LX-20™ compressor spray gun offers the same benefits of HVLP as our turbine guns.
A conventional piston compressor of around 5hp (3.75kw) should develop enough airflow for this spray gun; please check you machine's specifications.
It is essential equipment is cleaned after every job and operating instructions are followed. Failure to do so will void warranty
