HiKOKI M12VE Router In Case (1/2")
- Trade rated router with variable speed soft start motor
- Takes 1/2" and 1/4" shanked cutters
- Smooth plunge action 65mm depth
- 3-position turret depth stop with indicator
- Electronic control maintains speed under load
- Adjustable handle position for convenience and comfort
- Supplied with 1/2" collet chuck, 1/4" sleeve adaptor, side fence 30mm template guide, wrench and carrying case
Axcaliber Single Flute Straight Cutter - D=3 - X=8mm - S=1/4"From £9.88 £8.23
Axcaliber Dovetail Cutter - D=12.7 - X=12.7mm - K=14° - S=1/4"From £10.98 £9.15
Axcaliber A5 Foam Router Cutter PresenterSpecial Price £4.30 £3.58 was £13.58 £11.32 Save £9.28 £7.73
Axcaliber Twin Flute Straight Cutter - D=12.7, X=19mm - S=1/4"From £16.88 £14.07
Axcaliber Twin Flute Straight Cutter - D=9.5 X=25 - S=1/4"From £15.38 £12.82
The HiKOKI M12VE 1/2" Variable Speed Router is a quality trade rated router with plenty of power for all requirements. It features a powerful motor and variable speed with electronic control ensuring constant speed under load plus it has a 3-position turret depth stop with indicator. The speed range and excellent plunge depth allow you to undertake a wide variety of routing tasks, using 1/2" or 1/4" shank cutters. The handles are adjustable for convenience and comfort.
Supplied with 1/2" collet, 1/4" sleeve adaptor, side fence, 30mm template guide, tools and carrying case.
Collets Supplied | 1/4" and 1/2" |
Corded or Cordless | Corded |
Cutter Speed | 8,000 - 22,000 rpm |
EAN Barcode | 4966376295319 |
Model | M12VE |
Motor Power | 2,000 W |
Nett Weight | 5.3 kg |
Plug Fitted | 230V - UK BS89/13 13A Type G (2P+Earth) |
Plunge Stroke | 65 mm |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 94 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 83 dB(A) [3.0 dB] |
Spindle Lock | Standard Feature |
Vibration Cutting Wood [Uncertainty K] | 8.9 m/s² [3.4 m/s²] |
Voltage | 230 V |
