The Mafell LO 55 is highly versatile, quick and easy to set up and includes useful features for using in the workshop or on site. This powerful 1100W machine is fitted with Mafell's Intelligent Power Control System which supports restart and overload protection and constant speed under load. Use the colour LED's to understand the functions and operating status. There is also a deboost function in which the speed reduces by 30%, so burn marks can be avoided. The 'ergo-balanced' principle ensures that the machine is perfectly balanced, lowering vibration and giving you more control. The position of the handles guarantee a secure grip and easy handling.
Speed up your bit changes by simply releasing the locking lever, changing the bit and parking the lever - all without the need for tools. The fixed cutting depth can be adjusted by the Permafix button, releasing the lock for easy adjustment. There are graduated turrets with height fixing for recurring machine depths. The height adjuster in the base plate sits flush with its surface and ensures stability.
Supplied with: Parallel fence with fine adjustment, 8mm collet and 1/4 adaptor sleeve, a chip deflector, 20, 30 and 40mm template guide, template guide adaptor, extraction adaptor, a extraction adaptor for F-rail, all packed in a Mafell storage case MAX3.
