The Mafell LO 65 Ec router is powered by a high performance, high power, high torque, CUprex motor. This router will handle whatever task it is put to and with power to spare.
The LO 65 Ec features constant electronics to maintain speed under load. The speed is variable from 10 to 22 thousand rpm for perfectly matching the cutter/profile to the material, producing optimum results. The body of the router has a speed guide table for hardwood, softwood and plastics against cutter diameter.
The build quality is second to none, strong and robust without sacrificing refinement and precision. Fine depth and fine fence control come as standard. The LO 65 Ec router is a tough tool capable of the most demanding routing tasks, whilst retaining fine control for fine work.
Supplied with: Parallel guide fence with fine adjustment, 30mm template guide bush, 1/2" collet, dust extraction shroud, tools and instruction manual. Packed in a T-MAX power tool case.
