Mafell PSS 3100 SE Automatic Portable Panel Saw System - 230V
108162
108162
From £2,949.98 £2,458.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Out of Stock
  • Ideally suited to processing sheet and board on site
  • All the advantages of a static panel saw in a portable form
  • Cutting length up to 3,100mm, depth of 45mm
The Mafell PSS3100SE is a unique rail-guided, portable, automatic panel saw. The PSS3100SE brings all the advantages of a large static panel saw in a package that can be easily transported. The guide rail can be separated into two and the whole unit weighs less than 18.5kg.
With a cutting length up to 3,100mm and cutting depth of 45mm it is ideally suited to processing sheet and board materials, wherever it’s needed.
The saw and rail system can make plunge cuts or stopped cuts. It has a scoring feature for splinter free results in coated boards. Blades are available to suit a wide variety of materials from plywood and OSB to gypsum and cement board. The rail features non-slip inserts on the underside and does not require clamps.
The blade speed and feed rate are selected on the control pane, then you just press the rocker switch and the saw does the rest. At the end of the cut press the opposite side of the rocker switch and the saw automatically returns to the starting point.
Since you remain at the control point the PSS3100SE is safe to use. It includes an automatic riving knife that drops into place once the blade has reached the cutting depth.
Dust extraction is highly effective. The innovative blade guard in conjunction with the integrated suction channel in the rail eliminates practically all dust when connected to a suitable vacuum extractor.
Supplied with 160mm x 24T TCT saw blade.
Warranty Mafell 3 Year Warranty (Registration Required)
Register on the Mafell website and select NMA Agencies, Brighouse from Dealer options.
In case of a warranty claim please contact NMA Agencies NMA Customer Service Team on - Tel: 01484 400488
For warranty issues outside of the UK, tools must be returned to the UK at the customer's own cost.
Register now
