Makita SP6000J1 Plunge Saw, 2 Guide Rails & Bevel Guide - PACKAGE DEAL
717058
717058
From £439.98 £366.65
In Stock
  • Package deal comprises the Makita SP6000J1 Plunge Saw, 2 x Makita 1.5m Guide Rails, 2 x Makita Guide Rail Connectors and the Makita Adjustable Bevel Guide for Guide Rail SP6000.
  • Makita SP6000J1 Plunge Saw
  • Precise plunge saw with many features
  • Soft start and constant electronics
  • Max depth of cut at 90° 55mm and at 45° 39mm
  • Clear scale for precise saw adjustment
  • -2° negative angle available, also pre-set 22.5°
  • Can perform a cut 18mm from a wall
  • Adjustment for perfect fit on rail
  • 3 year Makita warranty available (registration required)
  • Saw supplied in Systainer case fitted with 48t blade
  • Makita 1.5m Guide Rail
  • Makita 1.5m guide rail
  • For SP6000J1 plunge saw
  • Rail has anti-slip coating, so clamping not required
  • Makita Guide Rail Connectors
  • Guide rail connectors for Makita Guide Rail system
  • Makita Adjustable Bevel Guide for Guide Rail SP6000
  • Quick and accurate way to cut angles with your guide rail
  • Bevel guide sits against edge of work and also in rail slot
  • Pivot and lock to the required angle
  • Graduated scale 0 - 45° left or right
  • Show More
Minimal tear-out, it’ll produce accurate cuts, each and every time.
If you need quick and accurate compound mitres or are looking to break down panels for carpentry, the Makita SP6000J1 Plunge Saw is the perfect choice.
Complete a range of cuts
In addition to performing plunge cuts, lengthways and crossways straight cuts and mitre cuts with angles in wood can also be performed while in firm contact with the workpiece.
Constant speed control
Thanks to the electronic speed control you’ll enjoy constant speed. The rotating speed is kept constant even under load conditions meaning it’s possible to get a fine finish.
Simple to adjust the depth of cut
For cleaner, safer cuts, you must set the cut depth so that no more than one blade tooth projects below your workpiece. Using proper cut depth helps to reduce the potential for dangerous kickbacks which can cause personal injury.
Speed adjusting dial
The blade speed can be adjusted by turning the adjusting dial. This is important to ensure the manufacturer’s recommended running speed is met. In general, higher speeds will allow you to cut workpieces faster. NB: If run at higher speeds than recommended, this can result in a poorer cut and compromise safety.
Highly accurate and well built with many features for the most precise cut when ripping and crosscutting. Powerful 1,300W motor (overload protected) with constant electronics to maintain speed under load for a very smooth cut. A variable speed dial allows you to select correct speed for material being cut. Cutting up to 55mm depth and 39mm at 45°, a 2mm scoring cut can quickly be made before the full depth cut, height and angles (-1° - 48°) are simply set with thumb screws, with positive stops for -1°, 22.5° and 45°. Supplied complete with Systainer case.
Makita 1.5m guide rail for the Makita SP6000J1 plunge saw. Replaceable splinter guard, anti-slip strips on the underside and top running strips for a smooth glide.
Guide rail connectors for Makita Guide Rail system.
A simple but accurate way to cut angles with your guide rail. Place the bevel guide against the edge of your material, pivot and lock to the required angle, attach to the guide rail and make your cut - it really is that simple. Graduated scale 0 - 45° left or right.
These products are manufactured in the UK, at the Makita factory in Telford
Warranty Makita 3 Year Warranty (Registration Required)
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
  • Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
  • The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
4.70 36
