PEANUT® 2 Connectors
AX1034198
AX1034198
- Self-clamping invisible connectors, create an incredibly strong joint
- Pulls the joint together from the inside
- Can be taken apart and reassembled many times
PEANUT® 2 Low Profile Router Guide Bush - 30mm O/DFrom £23.48 £19.57
Show more
Show less
PEANUT® 2 connectors are super tough glass-reinforced nylon. Use these in conjunction with the PEANUT® router jig or PEANUT® Mini Jig to produce strong, quick and highly accurate joints in board or sheet material. The connector design produces an incredibly strong joint.
The PEANUT® 2 connectors are self-clamping and pull the joint together from the inside. The result is an invisible connection that can be taken apart and reassembled many times.
