PEANUTĀ® 2 Cutter - 1/2" Shank
107367
107367
- Solid carbide PEANUT® router cutter
- 1/2" shank
- Use with PEANUT® router jig
JSP SpringFitā¢ Fold Flat Valved Respirator FFP2 (Pkt 10)From Ā£20.48 Ā£17.07
WoodSpur Torx Head Wood Screw Assortment (1,500 Pieces)From Ā£29.98 Ā£24.98
Axminster Professional Forged Flat Bar Clamp 200 x 80mmFrom Ā£15.58 Ā£12.98
Show more
Show less
The ultimate in self clamping, invisible connectors
Designed with the woodworking and furniture industry in mind, the Peanut Connecting System produces a wide variety of 45° and 90° joints quickly and efficiently using a ½" router and a drill.
This solid carbide PEANUT® router cutter (1/2" shank) cuts the special recess for the PEANUT® 2 connectors. Use in conjunction with the PEANUT® router jig.
EAN Barcode | 5060727934007 |
Shank Diameter | 1/2" (12.7 mm) |
