Robust Interior Curved Tool Rest - 305mm
- Enables maximum tool support when turning inside a bowl
- Top edge features hardened steel bar
- Turning tool glides smoothly and effortlessly
- Solid steel construction for years of faultless support
Explore the Robust Tool Rest range
Robust by name and robust by nature, these tool rests offer superb stability with a hard wearing, solid steel bar that provides a smooth turning experience.
Key features
Made from solid steel for strength, stability and smooth support.
A range of diameters, heights and lengths to suit a variety of lathes.
Stay close to your work with a tight radius - more control, less chance of knicks.
A comfortable fit whether you use a overhand or underhand grip.
Which rest do I need?
With a wide range of tool rests to suit a host of turning projects, explore our Robust Tools Rests and discover which is the right fit for you and your lathe.
Robust Interior Curved Tool Rests let you get to the heart of the matter. When working on the inside of a bowl, the curvature, angle and height of the rest enables you to position the rest close to the action for maximum tool support. A round, hardened steel bar welded to the top edge allows your turning tool to glide smoothly and evenly. The hardened bar will not dent or nick or ever need filing. Overall, the solid steel construction ensures these tool rests will give years of faultless support.
