Robust Low Profile Tool Rests
From £71.38 £59.48
12 Reviews
  • Low profile offers improved grip for fine and delicate cuts
  • Hardened steel bar, on the top edge will not dent or nick
  • Robust; solid steel construction
Explore the Robust Tool Rest range
Robust by name and robust by nature, these tool rests offer superb stability with a hard wearing, solid steel bar that provides a smooth turning experience.
Key features
Made from solid steel for strength, stability and smooth support.
A range of diameters, heights and lengths to suit a variety of lathes.
Stay close to your work with a tight radius - more control, less chance of knicks.
A comfortable fit whether you use a overhand or underhand grip.
Which rest do I need?
With a wide range of tool rests to suit a host of turning projects, explore our Robust Tools Rests and discover which is the right fit for you and your lathe.
Curved
Maximum tool support when turning bowls. There is a choice of interior and exterior rests.
Mini
For all lathes with 16mm (5/8") tool post diameter.
Comfort
Your hand fits in the radius of the rest for comfortable turning.
Low profile
For fine control and making delicate cuts.
The Robust Low Profile Tool Rests are perfect when making delicate cuts and fine control is most important. These tool rests are somewhat narrower in depth compared to the Robust Comfort Rests. The reduction in the depth allows you to place your fingers on the underside of the rest with your thumb on the top of the tool. Effectively trapping the tool between thumb and forefingers, thus giving you much greater control.
Each tool rest features a round, hardened steel bar welded to the top edge. This bar will not dent or nick and tools will continue to glide smoothly even after years of turning. Like the Comfort Rests, you can also drop the handle of your tool allowing for shear scraping and improved skew cutting action. Available with stem sizes to fit various lathes.
The 25.4mm(1") stem tool rests are compatible with the following Axminster lathes, Craft AC355WL, Trade AT350WL and AT406WL. They also fit the Robust American Beauty, Robust Sweet 16 and the Robust Scout. The 30mm stem tool rests are compatible with the Axminster Trade AT508WL lathe.
4.90 12
